Hi ,
is there anyway to find latest dockerfile or can NVIDIA open Dockerfile source ?
This can help us to run a same environment prior run it on AWS, since once VM created , it start to charge money, and i’d like to verify same docker environment with local build of Dockerfile firstly.
The NGC containers can be pulled and run on workstations and servers with Pascal and Volta GPUs, assuming you have Docker and the nvidia-docker utility installed on those systems. However, support for these systems is best effort only.
If you have access to one of these systems locally, you can pull the containers from NGC and test your application before deploying to AWS.
Please keep in mind that since the containers pulled from NGC include licensed software, they cannot be redistrubuted.
The images we provide on Dockerhub are different than those on NGC.
We have no plans to publish the Dockerfiles used to build NGC images - they would be of limited utility outside NVIDIA since they reference internal package repositories that could not be accessed from outside.
To modify the NGC images, NVIDIA recommends building on top of them (using the FROM directive in your Dockerfile) rather than rebuilding from scratch; there are example derivative Dockerfiles inside each image in the /workspace/docker-examples directory. This not only avoids a full rebuild but it also allows customizations to be now easily carried forward from one month’s release to the next.
We are not using docker but singularity in our lab. As as sysadmin, I am allowed to convert the NGC docker into singularity squashfs format for our research group usage or does each user need to to it by themself?
The NGC containers require the nvidia-docker utility to run them. Just converting the contents of NGC containers will not result in a functional alternative.
