Documentation of L4T 53.4.1 broken? Orin
Is it just me or is the documentation for r35.4.1 broken right now?
See e.g.
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/Security/SecureBoot.html#orin-reference-fuse-configuration-file
the codelisting doesnt have any content for me:
Already tried different browsers.
Note that its seems to be also in other releases e.g.
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/SD/Security/SecureBoot.html#orin-reference-fuse-configuration-file
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/Security/SecureBoot.html#orin-reference-fuse-configuration-file
but not in e.g.
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/SD/Security/SecureBoot.html#orin-reference-fuse-configuration-file
Thanks for reporting this issue, I will forward this issue to internal team to fix that problem.
We have published an update that fixed the blank code blocks issue on the Secure Boot page in r35.4.1, r35.3.1, r35.2.1, and r35.1.
Ive still found some (a lot?) of place where the code blocks are broken, e.g. https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/Security/OpTee.html#tool-for-ekb-generation
Could you help to take a screenshot to let me to check with internal team?
for me this was in firefox and chromium:
But its not just that place, it was multiple places and i cant get them all for you ;)
Thank you to point this problem out, I have forwarded it to internal team to fix it.
We have fixed the broken docs and published the updated builds (34.1, 35.1, 35.2.1, 35.3.1, and 35.4.1). Thanks.
