I want to be able to boot a new Jetson TX2 from Micro SD card with a TX2 OS already written to sd card.
That means all I need is the micro sd card to run TX2 from and new similar TX2 . This is the case for raspberry Pi.
Just wondering if this was possible for Jetson TX2. Especially a TX2 bought as a module before connecting to a carrier board.
So question is, does a new Jetson TX2 Module come with Default OS already flashed into it?
Because if so, I know it should work automatically, like with a raspberry Pi.
NOTE: The carrier board is same as used in the OS that was flashed to the micro SD card.
