Does AGX Orin support another FAN_TACH pin?
We have two Fans in our system, but we found that there is only on FAN_TACH pin, does it is possiable to use another pin as FAN_TACH for the other FAN ?
How to add 2nd fan configuration for nvfancontrol service
please check Topic 348680 for the steps to edit /etc/nvpower/libjetsonpower/jetsonpower_t234.conf and also /etc/nvfancontrol.conf for adding 2nd fan into nvfancontrol service.
Hello @kayccc
This is just add another PWM FAN, my question is whether there is another FAN_TACH pin to measure the FAN speed?
There is only one FAN_TACH input.
There are I2C based external fan controllers. Example:
Does it possiable to use normal to simulate the FAN_TACH signal?
If you mean a GPIO, no that is not supported. The tach is monitored with a SFIO (special function I/O) and you can see in the pinmux that the FAN_TACH pin is set to the NV_THERM_FAN_TACH0 option, not GPIO.
