Does AIAA server API support https protocol?
Hi sirs,
From AIAA structure
Between 3D Slicer client and AIAA server support http. Is it support https protocol?
Yes, AIAA supports also https protocol.
You will need to first prepare your certificate and key.
If you don’t know how to, can refer to here: How To Create a Self-Signed SSL Certificate for Apache in Ubuntu 16.04 | DigitalOcean
Then you can put those files into your workspace (and mount them in docker using -v option).
Then if you are running V3.1 (nvcr.io/nvidia/clara-train-sdk:v3.1.01),
you pass the following flags when you start AIAA:
“–ssl true --ssl_cert_file [path to your certificate file] --ssl_pkey_file [path to your key]”
Hi sir,
Thanks your response. So when I want to use 3D slicer plugin AIAA server. I can specify AIAA server with https protocol as follow pictures (red part), right?
slicer
Yes, looks right.
Hi sir,
Thank you.
