I am working on DPA/FlexIO device-side code on BlueField-3, and I would like to confirm whether CAS / compare-and-exchange is supported on BF3 DPA.
My environment:
- Hardware: NVIDIA BlueField-3 SoC, MT43244
- NIC: BlueField-3 integrated ConnectX-7 network controller
- Firmware version: 32.47.1026
- DOCA/FlexIO version: libflexio 25.10.3034
- dpacc version: 2.0.0.73
- DPA target: -mcpu=nv-dpa-bf3
I tested several C11 standard atomic operations in the DPA device code, and I found that the CAS/compare-swap operation could not be compiled.
My test code:
#include <stdint.h>
#include <stdatomic.h>
__dpa_global__ void dpa_cas_repro(uint64_t out_daddr)
uint64_t *out = (uint64_t *)(uintptr_t)out_daddr;
atomic_uint c11_value;
uint32_t c11_expected;
uint32_t c11_ok;
uint32_t builtin_value;
uint32_t builtin_expected;
uint32_t builtin_ok;
atomic_init(&c11_value, 0u);
c11_expected = 0u;
c11_ok = atomic_compare_exchange_strong_explicit(&c11_value,
&c11_expected,
123u,
memory_order_seq_cst,
memory_order_seq_cst);
builtin_value = 0u;
builtin_expected = 0u;
builtin_ok = __atomic_compare_exchange_n(&builtin_value,
&builtin_expected,
456u,
0,
__ATOMIC_SEQ_CST,
__ATOMIC_SEQ_CST);
out[0] = c11_ok;
out[1] = atomic_load_explicit(&c11_value, memory_order_seq_cst);
out[2] = builtin_ok;
out[3] = builtin_value;
Build command:
/opt/mellanox/doca/tools/dpacc \
/home/pengyu/dpa_cas_repro/dpa_cas_repro.c \
-o /home/pengyu/dpa_cas_repro/dpa_cas_repro.a \
-hostcc=gcc \
--devicecc-options="-DE_MODE_LE,-Wall,-Wextra,-Wpedantic,-ffreestanding,-mcmodel=medany,-O2" \
-mcpu=nv-dpa-bf3 \
--app-name=dpa_cas_repro_app
Compiler error:
/home/pengyu/dpa_cas_repro/dpa_cas_repro.c:16:11: error: builtin not supported for current target CPU
16 | c11_ok = __c11_atomic_compare_exchange_strong(&c11_value,
/home/pengyu/dpa_cas_repro/dpa_cas_repro.c:24:15: error: builtin not supported for current target CPU
24 | builtin_ok = __atomic_compare_exchange_n(&builtin_value,
2 errors generated.
Is CAS / compare_exchange unsupported on BlueField-3 DPA device code? If not, is there any DPA-specific intrinsic or DOCA API that provides CAS-like semantics on BF3?
