Does CoarseToFineStereoDepth sample require extrinsics and Intrinsincs?
I am trying to run the stereo_matching_depth sample but I get this error :
2020-07-30 16:13:54.752 PANIC packages/stereo_depth/CoarseToFineStereoDepth.cpp@113: Failed to create stereo matcher (error code 15)
In the isaac.stereo_depth.CoarseToFineStereoDepth Proto doc say
baseline [double] [default=0.12]: default baseline for the stereo camera (in meters) if no extrinsics provided so I thought that no extrinsics data are required but I still get the same error when I delete the extrincs edge { "source": "TXn/TX/extrinsics", "target": "depth_estimation/isaac.stereo_depth.CoarseToFineStereoDepth/extrinsics" }, so I tryed to feed extrincs data with the following cpp codlet :
namespace isaac {
void TX::start() {  tickOnMessage(rx_inLcam());}
void TX::tick() {
//Extrinsincs
  Pose3d extrinsics;
  double qq[4] = {0,0,0,0};
  extrinsics.rotation = SO3<double>::FromQuaternion(Quaterniond(qq));
  extrinsics.translation = Vector3d(0.06,0,0);
  const auto ext = tx_extrinsics().initProto();
  ToProto(extrinsics, ext);
  tx_extrinsics().publish();
  LOG_INFO("OK \n");
}}  // namespace isaac
But still the same error so I tried to modify the Intrinsincs data computed with matlab stereo calibration app with the following cpp :
#include "TX.hpp"
#include <memory>
#include <utility>
#include "engine/core/assert.hpp"
#include "engine/gems/image/conversions.hpp"
#include "engine/gems/image/utils.hpp"
#include "messages/camera.hpp"
#include "messages/math.hpp"
namespace isaac {
void TX::tick() {
//Extrinsincs
  Pose3d extrinsics;
//Intrinsincs
  auto out = tx_outLcam().initProto();
  // Pinhole
  auto pinhole = out.initPinhole();
  ToProto(Vector2d(3147.54098361, 3160.49382716), pinhole.getFocal());//1280*12/4.86 & 960*12/3.66  Foc len [8.525929042561033e+02,8.549701455135702e+02]
  ToProto(Vector2d(519.4719202793973, 693.0736876181506), pinhole.getCenter());//principal point [6.930736876181506e+02,5.194719202793973e+02]
  pinhole.setCols(1280);
  pinhole.setRows(960);
  // Distortion
  auto distortion = out.initDistortion();
  distortion.setModel(DistortionProto::DistortionModel::BROWN);
  Vector5d disto;
  disto << 0.035, 0.035, 0, 0, 0;
  ToProto(disto, distortion.getCoefficients());
  //Get Cam
  auto Lin= rx_inLcam().getProto();
  auto Rin = rx_inRcam().getProto();
  //auto Lout = tx_outLcam().initProto();
  //auto Rout = tx_outRcam().initProto();
  //Lout.setColorSpace(ColorCameraProto::ColorSpace::RGB);
  //Rout.setColorSpace(ColorCameraProto::ColorSpace::RGB);
  //Publish CamProto
  ToProto(out,Lin);
  ToProto(out,Rin);
  tx_inLcam().publish();
  tx_inRcam().publish();
  LOG_INFO("OK \n");
I don’t know how to modify the Intrinsincs data of the camera proto but I tried and the code don’t compile because of the wrong proto handeling, I could probably make it work with some more work but I don’t know if it is really necessary. If the error come from something else I don’t want to get into that now because my camera have a 12mm lens with no distortion.
I did this code by looking at the zed.cpp code and the opencv tuto, I modified the opencv tuto to make a rgb to grey script
So do I need to make a the cpp code to send extrinsics and Intrinsincs data ? If I need to do it, could you help me a bit with my code please ?
Thank you !
regards
Planktos
Hi, you can check that the custom codelet ticks with the same frequency as the CoarseToFineStereoDepth using the Sight Statistics widget.
Thanks but indeed my code don’t run so frequency is 0, I will create a new post with my issue in my code because I suppose that CoarseToFineStereoDepth sample need a custom Intrinsincs
