Does ConnectX-4 support l2vpn-xconn-point2point in HW
I am looking for a NIC card with SFP+ adapter that allows two ports to be connected transparently.
It should not be a switch, as all frames should be transported transparently.
This should be done in hardware and not burden the CPU.
At Cisco, this is the l2vpn xconn point-to-point service:
Furthermore, I would like to be able to capture the Rx/Tx stream as mirroring, filter it and reduce the frame
Like the Cisco function
mirror first 100
Can the ConnectX-4 offer these functions?
Or how do I achieve this with other functions in Hw?
Hi qrun,
Welcome, and thank you for posting your inquiry to the NVIDIA developer forums.
The ConnectX-4 does not support this functionality, and is functionally end-of-life. No further updates to the current feature set are planned.
We highly recommend reaching out to our Sales and Solutions team with this inquiry. They will be able to assist you with developing a solution for your unique business needs. They can be reached via the following contact form: https://www.nvidia.com/en-us/contact/sales/
Thanks, and best regards,
NVIDIA Enterprise Experience
