The documentation says “Added support for High Availability and load balancing for Virtual Functions of different physical ports in SwitchDev SR-IOV mode.” with “HCAs: ConnectX-4 Lx and above” in the release note section.
However, when I follow the instrusions in documentation’s “SR-IOV VF LAG” section,the network does’nt work, and dmesg shows lots of message like:
[77770.535190] mlx5_core 0000:3b:00.0: mlx5_cmd_check:795:(pid 60089): CREATE_FLOW_TABLE(0x930) op_mod(0x0) failed, status bad resource state(0x9), syndrome (0x98afbb)
[77770.537545] mlx5_core 0000:3b:00.0: E-Switch: Failed to create FDB Table err -22 (table prio: 3, level: 0, size: 4194304)
[77770.772810] mlx5_core 0000:3b:00.0: mlx5_cmd_check:795:(pid 60146): CREATE_FLOW_TABLE(0x930) op_mod(0x0) failed, status bad resource state(0x9), syndrome (0x98afbb)
[77770.775134] mlx5_core 0000:3b:00.0: E-Switch: Failed to create FDB Table err -22 (table prio: 2, level: 0, size: 4194304)
So, Does ConnectX4-Lx Support HW LAG(SR-IOV VF LAG)? or the feature only works for ConnectX5 and later?
