The following link contains the following code:
http://on-demand.gputechconf.com/gtc/2012/presentations/S0338-GTC2012-CUDA-Programming-Model.pdf
__device__ float buf[1024];
__global__ void dynamic(float *data)
int tid = threadIdx.x;
if(tid % 2)
buf[tid/2] = data[tid]+data[tid+1];
__syncthreads();
if(tid == 0) {
launch<<< 128, 256 >>>(buf);
cudaDeviceSynchronize();
__syncthreads();
cudaMemcpyAsync(data, buf, 1024);
In this case, the copy function cudaMemcpyAsync() when called from the GPU’s kernel-function does use DMA or use GPU-cores with dynamic parallelism (calls another kernel-function and copies using the GPU-cores)?
