I don’t see any restriction in the docs here: https://docs.nvidia.com/deeplearning/sdk/cudnn-developer-guide/index.html#cudnnSetRNNDescriptor_v6
For the dataType argument it says:
dataType
Input. Compute precision.
I’m guessing it does not support CUDNN_DATA_INT8 because when I modified the RNN example (RNN_example.cu) that comes with CuDNN 7.2 so that it has:
cudnnErrCheck(cudnnSetRNNDescriptor_v6(cudnnHandle,
rnnDesc,
hiddenSize,
numLayers,
dropoutDesc,
CUDNN_LINEAR_INPUT, // We can also skip the input matrix transformation
bidirectional ? CUDNN_BIDIRECTIONAL : CUDNN_UNIDIRECTIONAL,
RNNMode,
RNNAlgo, // Can be changed to use persistent RNNs on Pascal+ GPUs.
CUDNN_DATA_INT8)); // this is line 285
When I compile and run I get:
$ ./RNN_example_int8 100 4 512 64 2
cuDNN Error: CUDNN_STATUS_NOT_SUPPORTED RNN_example_int8.cu 285
So I’m assuming based on this not_supported status that it isn’t supported even though the docs don’t stipulate a restriction. Can anyone at Nvidia confirm? If it’s not supported can the API docs be updated to reflect that?
Also, will CUDNN_DATA_INT8 be supported for this model in the future?
Phil
(wishing I could just take a peek at the CuDNN source to see if this is indeed the case, but alas, it’s not open source)
