Thanks for your reply. I also tried MiTK. Following is a part of the logs that seem to indicate AIAA got the data. However I am not seeing any visual result on MITK and I don’t have a case to compare with.
[2021-01-05 19:29:09] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Load Data from: /claraDevDay/tmp/AIAA//sessions/30bffbec-4f8b-11eb-bbf4-0242ac110004/tmp.0.WrXa6Y.nii.gz
[2021-01-05 19:29:09] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Using Image: /claraDevDay/tmp/AIAA//sessions/30bffbec-4f8b-11eb-bbf4-0242ac110004/tmp.0.WrXa6Y.nii.gz
[2021-01-05 19:29:09] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Using Params: {'foreground': '[[396,322,81],[396,322,81],[425,297,81],[425,297,81],[397,312,81],[397,312,81],[424,301,81],[424,301,81],[422,295,81],[422,295,81],[393,298,81],[393,298,81],[370,317,81],[370,317,81],[367,311,81],[367,311,81],[362,318,81],[362,318,81],[411,324,81],[411,324,81],[400,336,81],[400,336,81],[422,318,81],[422,318,81],[422,318,81],[422,318,81],[424,289,81],[424,289,81],[405,302,81],[405,302,81],[380,325,81],[380,325,81],[376,331,81],[376,331,81],[404,310,81],[404,310,81],[383,321,81],[383,321,81],[383,321,81],[383,321,81],[373,317,81],[373,317,81],[427,282,81],[427,282,81]]', 'background': '[]', 'image_original': '/claraDevDay/tmp/AIAA//sessions/30bffbec-4f8b-11eb-bbf4-0242ac110004/tmp.0.WrXa6Y.nii.gz'}
[2021-01-05 19:29:09] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Run Pre Processing
[2021-01-05 19:29:09] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Pre-Processing Input Keys: dict_keys(['image', 'image_path', 'params'])
[2021-01-05 19:29:09] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Run Transforms
[2021-01-05 19:29:09] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Input Keys: dict_keys(['image', 'image_path', 'params'])
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Time consumed by Transform (LoadNifti): 0.8864603042602539
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Time consumed by Transform (DeepGrow2DGetOneSlice): 0.0006926059722900391
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Time consumed by Transform (DeepGrow2DScaleByResolution): 0.02539229393005371
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Time consumed by Transform (DeepGrow2DCropCenterVolume): 0.000667572021484375
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Time consumed by Transform (DeepGrow2DFixedMeanStdNormalization): 0.0002837181091308594
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Time consumed by Transform (DeepGrow2DAddUserPoints): 0.007464170455932617
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Time consumed by Transform (DeepGrow2DMergeImages): 0.000545501708984375
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - PRE - Time consumed by Transform (ConvertToChannelsFirst): 7.414817810058594e-05
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - ++ Total Time consumed for pre-processing: 0.9225304126739502
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Pre-Processing Output Keys: dict_keys(['image_path', 'params', 'image.affine', 'image.original_affine', 'image.file_name', 'image.file_format', 'image.original_shape', 'image.original_shape_format', 'image.spacing', 'image.as_canonical', 'image.shape_format', 'image.slice_index', 'image.resolution_factor', 'image.start_px', 'image.end_px', 'foreground.shape_format', 'background.shape_format', 'image'])
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.trtis_inference) - Run TRTIS Inference for: clara_deepgrow
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - ShapeFormat: CHW
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.trtis_inference) - Original ShapeFormat: CHW
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - ++ Total Time consumed for inference: 0.10468339920043945
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Inference Output Keys: dict_keys(['image_path', 'params', 'image.affine', 'image.original_affine', 'image.file_name', 'image.file_format', 'image.original_shape', 'image.original_shape_format', 'image.spacing', 'image.as_canonical', 'image.shape_format', 'image.slice_index', 'image.resolution_factor', 'image.start_px', 'image.end_px', 'foreground.shape_format', 'background.shape_format', 'image', '*.shape_format', 'model'])
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Run Post Processing
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Post-Processing Input Keys: dict_keys(['image_path', 'params', 'image.affine', 'image.original_affine', 'image.file_name', 'image.file_format', 'image.original_shape', 'image.original_shape_format', 'image.spacing', 'image.as_canonical', 'image.shape_format', 'image.slice_index', 'image.resolution_factor', 'image.start_px', 'image.end_px', 'foreground.shape_format', 'background.shape_format', 'image', '*.shape_format', 'model'])
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - POST - Run Transforms
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - POST - Input Keys: dict_keys(['image_path', 'params', 'image.affine', 'image.original_affine', 'image.file_name', 'image.file_format', 'image.original_shape', 'image.original_shape_format', 'image.spacing', 'image.as_canonical', 'image.shape_format', 'image.slice_index', 'image.resolution_factor', 'image.start_px', 'image.end_px', 'foreground.shape_format', 'background.shape_format', 'image', '*.shape_format', 'model'])
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - POST - Time consumed by Transform (DeepGrow2DGetPrediction): 0.01916813850402832
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.inference.inference_utils) - POST - Time consumed by Transform (CopyProperties): 0.00012111663818359375
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - ++ Total Time consumed for post-processing: 0.019738435745239258
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - ++ Total Time consumed for ALL: 1.0473146438598633
[2021-01-05 19:29:10] [INFO] (nvmidl.apps.aas.actions.inference_engine) - FilePath: /tmp; FileName: tmpzmk5t0ka
[2021-01-05 19:29:11] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Result File: /tmp/tmpzmk5t0ka_model.nii.gz
[2021-01-05 19:29:11] [INFO] (nvmidl.apps.aas.actions.inference_engine) - Result Params: {}
[2021-01-05 19:29:11] [INFO] (nvmidl.apps.aas.www.api.api_v1) - Result Json: {}
[2021-01-05 19:29:11] [INFO] (nvmidl.apps.aas.www.api.api_v1) - Result File: /tmp/tmpzmk5t0ka_model.nii.gz
[2021-01-05 19:31:19] [INFO] (schedule) - Running job Every 5 minutes do cleanup_sessions({'30bffbec-4f8b-11eb-bbf4-0242ac110004': <nvmidl.apps.aas.actions.sessions.SessionInfo object at 0x7f4842a50f60>}) (last run: 2021-01-05 19:26:19, next run: 2021-01-05 19:31:19)
[2021-01-05 19:36:19] [INFO] (schedule) - Running job Every 5 minutes do cleanup_sessions({'30bffbec-4f8b-11eb-bbf4-0242ac110004': <nvmidl.apps.aas.actions.sessions.SessionInfo object at 0x7f4842a50a58>}) (last run: 2021-01-05 19:31:19, next run: 2021-01-05 19:36:19)```
