Does Deepsort supports Mulitple GPU?
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.0
• TensorRT Version 8.2.0
• NVIDIA GPU Driver Version (valid for GPU only) 470
• Issue Type( questions, new requirements, bugs) Question
set gpu-id=1/0 in different sources in sample config txt file and enable Deepsort Tracker
to run deepstream-app on multiple T4’s, i set gpu-id=1 and 0 also “nvbuf-memory-type=3”.
But internal data error occured.
I want to ask does Deepsort tracker supports multiple GPUs?
Same Question is for 2 points-
*) Multiple GPU’s but same type like 2 T4s
*) Multiple GPU’s but different types like T4 and TitanX
should support, but we didn’t verify all the cases.
ok thanks
