I´m executing deepstream-app from a Python script using subprocess module. With this, what I´m trying to do is to catch any error of deepstream-app in the Python script.
I would like to know if deepstream-app proccess returns any kind of error code or exception when an error occurs in its execution.
HI,
You can enable gst debug to capture more log for debug.
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-5.1$ deepstream-app --help-all
Usage:
deepstream-app [OPTION?] Nvidia DeepStream Demo
Help Options:
-h, --help Show help options
–help-all Show all help options
–help-gst Show GStreamer Options
GStreamer Options
–gst-version Print the GStreamer version
–gst-fatal-warnings Make all warnings fatal
–gst-debug-help Print available debug categories and exit
–gst-debug-level=LEVEL Default debug level from 1 (only error) to 9 (anything) or 0 for no output
–gst-debug=LIST Comma-separated list of category_name:level pairs to set specific levels for the individual categories. Example: GST_AUTOPLUG:5,GST_ELEMENT_*:3
–gst-debug-no-color Disable colored debugging output
–gst-debug-color-mode Changes coloring mode of the debug log. Possible modes: off, on, disable, auto, unix
–gst-debug-disable Disable debugging
–gst-plugin-spew Enable verbose plugin loading diagnostics
–gst-plugin-path=PATHS Colon-separated paths containing plugins
–gst-plugin-load=PLUGINS Comma-separated list of plugins to preload in addition to the list stored in environment variable GST_PLUGIN_PATH
–gst-disable-segtrap Disable trapping of segmentation faults during plugin loading
–gst-disable-registry-update Disable updating the registry
–gst-disable-registry-fork Disable spawning a helper process while scanning the registry
