Does Deepstream run on an ARM server equipped with A100 GPU?
I couldn’t find an official guide. ( There are only 2. Jetson setup and dgpu setup(x86))
If it can be run, I want to know how to install it on the ARM server equipped with A100 GPU.
Thank you.
We maitain and test on dGPU(x86) and Jetson devices, we never tested on ARM server. so i suggest you use x86 server or Jetson devices.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#platform-and-os-compatibility
OK. Thank you!
