I ran the official DGX Spark Field Diagnostic on my system without any cable connected to the ConnectX-7 ports.
System details:
- DGX Spark / AI TOP ATOM
- Ubuntu 24.04.5 LTS
- DGX Spark software version 7.5.0
- Kernel: 6.17.0-1032-nvidia
- FieldDiag: 2.0.4-1
- ConnectX-7 firmware: 28.45.4028
- Secure Boot disabled
All tests passed except CX7Stress:
- GpuStress: PASS
- C2CStress: PASS
- CpuStress1/2: PASS
- PowerStress: PASS
- ThermalStress: PASS
- FioSSD: PASS
- MemStress: PASS
- CX7Stress: FAIL
CX7Stress failed almost immediately during topology initialization:
Error Code: 017-000-0-000000000001
Virtual ID: CX7Stress
Test: ibstress
Notes: Failed
The relevant exception was:
KeyError: '/dev/mst/mt4129_pciconf0'
ERROR - Exception during RunIbStress - '/dev/mst/mt4129_pciconf0'
The log also showed:
MST PCI module is not loaded
MST PCI configuration module is not loaded
No MST devices were found.
The documentation describes CX7Stress as running an InfiniBand stress test in “PHY loopback mode,” but it is not clear whether this loopback is configured internally by the diagnostic or requires an external physical cable/loopback adapter.
Could anyone please clarify:
- Is CX7Stress expected to pass on a single DGX Spark with nothing connected to its ConnectX-7 ports?
- Does it require a QSFP cable connecting the two ports, a second DGX Spark, or a dedicated loopback adapter?
- Is the missing
/dev/mst/mt4129_pciconf0error an expected result when no cable is connected, or does it indicate an MFT/driver setup problem? - What is the officially supported physical setup for running CX7Stress?
I would like to determine whether this failure is simply caused by running the test without a cable before treating it as a system fault.
Thank you.
