I am trying to make two Jetson AGXs communicate via ethernet with as low latency as possible using UDP protocol. The default request-response latency measured by netperf is around 200 microseconds. I am looking for ways to reduce this and all suggestions are welcome.
Looking at the network stack, I came across the fact that Jetson uses little endian byte order while network uses big endian order. So, for a request response scenario, byte order conversion needs to be done 4 times
–>start
Host sender (LE)–> BE → send to client
Client receiver BE → LE
Client sender LE–> BE -->send to host
Host receiver BE → LE
→ end
Of course this is a very simplified picture and I have omitted all parts of the stack unrelated to byte ordering. My question is, does this 4 time conversion impact the latency significantly? If one were to use systems with big endian ordering, given everything else remains same, would that reduce network latency by any measurable amount?
