I try to use anti-aliasing and super resolution of DLSS for one view. Therefore I insert two DLSS passes after finishing constructing view.
- DLSS pass 1: Use DLAA mode and generate the evaluated result.
- DLSS pass 2: Use PERFORMANCE mode with input which is evaluated result of pass 1
Each pass has its own feature instance.
But I found that I can not enable both two passes at same time, or the second pass will generate black result.
