Hi, we conducted some experiments to disable some GPC/TPC to reduce power consumption.
However, based on our test data, disabling GPC/TPC has little impact on power consumption.
Could you please help confirm if there is a GPC/TPC power gating switch in Thor’s GPU?
Thank you.
| GPU |
GPU_PG_MASK |
GPU freq |
temperature 81 (mW) |
temperature 41 (mW) |
| 1GPC(14CPU) |
16257(0b11 1111 1000 0001) |
54M |
3636 |
2328 |
| 3GPC(14CPU) |
1 (0b00 0000 0000 0001) |
54M |
3804 |
2556 |
| Diff |
168 |
228 |
Yes, GPC/TPC power gating is supported. However, the actual power number difference may not be large because:
- There are other GPU low power features suppressing the power
- The GPU rail voltage is low
The power difference should be more obvious when running a GPU workload.
To easily confirm whether the power gating is applied, use tegrastats to check which GPC clocks are active. For example:
- When only 1 GPC is active, it shows in tegrastats as GR3D_FREQ @[0,1574,0]
- When 3 GPCs are active, it shows as GR3D_FREQ @[1574,1574,1574].
