Does Isaac ROS 4.0.0 officially support Jetson Orin?
I wanted to ask whether the newly released Isaac ROS 4.0.0 officially supports the Jetson Orin series.
I’ve gone through the latest documentation and release notes, but I couldn’t find any section explicitly stating Orin support — most references seem to mention Jetson Thor instead.
Could you please clarify whether Isaac ROS 4.0.0 is compatible with Jetson Orin platforms?
Thank you very much for your help!
Best regards,
Hi @hjkim15 ,
Thanks for your question. Currently, Isaac ROS 4.0 does not support Jetson Orin.
However, our Isaac ROS 3.2 and future 3.X releases will continue to support Jetson Orin:
