I am working on a soft tissue simulation for surgical scenario involving cutting and suturing, and I’m exploring whether this can be implemented within Isaac Sim.
The goal is to simulate deformable soft tissue that can be cut and later sutured similar to what is needed in robotic surgical environments.
I would like to know:
- Does Isaac Sim / PhysX support soft-body or deformable simulations suitable for tissue-like material?
- Are there recommended approaches for implementing suturing interactions?
- Are there any examples, tutorials or documentation related to deformable body simulation or surgical interaction?
If anyone has attempted something similar or can point to relevant resources or workflows, it would be greatly appreciated.
Hi @shubham.prasad1 thank you for posting your question.
Yes, deformables are supported in Isaac Sim. Isaac Sim 6.0.0 integrates PhysX 109.0 API, and here is some examples on how to create deformables through code. Deformable Bodies — Omni Physics
This depends on how much dynamics fidelity you want from this. If joining two deformable materials is enough, then it is possible to use Attachments in deformables: Deformable Bodies — Omni Physics The way I would approach this simulation is to have two deformables that are attached initially. As cutting happens, you would programmatically disable the attachments. When suturing you can re-enable the attachments. That said, this would be a very coarse proxy to an actual suturing. If you are looking for simulation that can join the deformable tissue through a taught thin suture, then from my experience thin threads can easily interpenetrate deformables in PhysX. I would recommend also considering Newton for deformable simulation: GitHub - newton-physics/newton: An open-source, GPU-accelerated physics simulation engine built upon NVIDIA Warp, specifically targeting roboticists and simulation researchers. · GitHub
Yes, you can refer to the scripts I attached earlier or in Isaac Sim 6.0.0, you can find interactive examples if you launch Isaac Sim and navigate to Windows>Example>Physics Examples, then go to the examples window and open Deformables>Deformable Attachments
Hello!
We noticed that this topic hasn’t received any recent updates from anyone reporting this issue, so we are closing it for now to help keep the forum organized.
If you are still experiencing this issue or have related questions, please create a GitHub Discussion or Issue in the Isaac Sim repository and include a link to this topic along with updated details. Mentioning or linking to this original topic provides helpful context and makes it easier for others to assist you.
Best regards,
