Does IsaacSim support soft joint limits?
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX 4090
  • Driver Version: 550.107.02
Topic Description
Detailed Description
For an unactuated joint (a joint without drive), we can still configure stiffness and damping settings (In Revolute Joint > Advanced API).
I initially thought that these were meant to produce the soft-limit behavior as described in the (PhysX documentation. However, I didn’t see any noticeable difference in the simulator.
For example, in the [Isaac Sim Assets Path]/Isaac/Robots/Cartpole/cartpole.usd asset, setting the joint limit to (-90, 90) for the poleJoint results in the same hard limit behavior regardless of the values set in RevoluteJoint > Advanced API.
Does the current version not support soft limits, or is there another method to enable soft limit functionality?
Welcome to the community!
If the joint you’re working with is part of an articulation, soft limits are not supported.
