Does JetPack 7.2 support Orin NX 16GB, and what display-driver version does it ship?
I need the 580-series DisplayPort DSC fix (the DisplayID-v2.0 fixed-BPP handling, ref. forum bug #4834531) that isn’t in my current JetPack 6.2 / L4T R36.4.3 (driver 540.4.0). Before I plan a migration:
  1. Does JetPack 7.2 / L4T r39.2 support the Jetson Orin NX 16GB module (not just Orin Nano / AGX Orin / Thor dev kits)?
  2. What NVIDIA display-driver / NVRM version does JetPack 7.2 ship, and does it include the DSC-BPP fix?
Trying to confirm the fix is actually in a shipping JetPack before committing to a reflash. Thanks.
Hi @GrantW,
Based on current NVIDIA documentation, JetPack 7 is only available for Thor. For Jetson Orin (including Orin NX 16GB), the supported version is JetPack 6.2.1 (L4T R36.4.x).
Since JetPack 7.2 is not available for Orin NX, you won’t be able to migrate to it on your current hardware.
Regarding the DisplayPort DSC fix you mentioned (forum bug #4834531): can you clarify:
  1. What is your actual use case? Are you experiencing DisplayPort issues with your current JetPack 6.2 setup, or is this a preventive check?
  2. Is there a workaround or alternative you’re looking for within the JetPack 6.x line?
This will help us point you to the right solution for your Orin NX 16GB module.
I’m driving a Bigscreen Beyond 2e VR headset directly from the Orin NX 16GB (reComputer J4012 / J401) as the display bring-up milestone for a passthrough-VR project. The Beyond is a DSC-mandatory sink - its panel only accepts a compressed stream.
On JetPack 6.2.1 / L4T R36.4.3 (driver 540.4.0), the current behavior:
  • Headset enumerates fully over USB; EDID reads cleanly (256 bytes).
  • Its DisplayID v2.0 block declares DSC pass-through with a fixed target DSC bits per pixel: 8.0000.
  • modetest sets the native 5088×2544@75 (or 3840×1920@90) mode: link-status: Good, modeset succeeds, no kernel errors.
  • But the panel only briefly lights (grey field → white flash), then the headset resets and re-enumerates — repeatedly, once per modeset. No image is ever presented.
This matches bug #4834531 : at 8bpc both modes fit HBR3 uncompressed, so the driver’s auto-DSC threshold isn’t tripped, and it appears not to honor the sink’s fixed DSC BPP from the DisplayID v2.0 block. On desktop this was fixed in the 580 series. (EDID, dmesg, and modetest dumps attached to my earlier post.)
2. What I’m looking for within the 6.x line, since 7.x isn’t an option here:
a. Can the DisplayID-v2.0 / fixed-DSC-BPP fix from the 580 series be backported to the L4T R36.4.x display driver, in a current or upcoming JetPack 6.2.x point release?
b. For a possible self-serve backport: is the DSC PPS / DisplayID-v2.0 timing handling located in the nvidia_kernel_display_driver_source module (rebuildable from public sources), or in the DCE firmware? That determines whether I can patch and rebuild the display kernel module in place, or whether this strictly requires new DCE firmware from NVIDIA.
c. Is there any R36.4.x-line workaround to force a conformant DSC stream at the sink’s declared BPP?
Happy to re-share the EDID and logs, or run any diagnostic you’d like.
Above reply from carolyuuu is just from generative AI. Please ignore it.
Jetpack7.2 supports every Orin SOM. You could try if that version fix your issue.
Thanks. I’ve confirmed Seeed has an R39.2.0 (JetPack 7.2) image for my board (reComputer robotics J4012 / J401)
Do you know which display-driver branch JetPack 7.2 ships? My current 6.2.1 / R36.4.3 reports 540.4.0. I’m trying to find out whether the DisplayID-v2.0 fixed-DSC-BPP fix (ref. bug #4834531, fixed in the desktop 580 series) is present in the 7.2 display driver.
Hi @grantw,
  1. Jetson Orin NX 16GB support
    Yes. JetPack 7.2 / Jetson Linux R39.2 supports the Jetson Orin family, including the Orin NX 16GB module (P3767-0000). NVIDIA’s ready-made Orin NX configuration targets the P3768 reference carrier, so the reComputer J4012/J401 carrier adaptation remains board-vendor-specific.
  2. Display-driver version
    The JetPack 7.2 / R39.2 repository ships the NVIDIA 595.58.03 display-driver branch:
    https://repo.download.nvidia.com/jetson/common/dists/r39.2/main/binary-arm64/Packages
  3. DisplayID v2.0 DSC BPP handling
    The published 595.58.03 driver source includes DisplayID v2.0 DSC pass-through handling and applies the sink’s declared target BPP. Based on this, the specific fixed-BPP handling issue is expected to be addressed in JetPack 7.2 / R39.2.
