Does Jetson Orin NX Support Two Independent Displays Through DisplayPort MST?
We are evaluating the Jetson Orin NX for an application that requires two independent 4K display outputs, with different content shown on each display.
The Jetson Orin Product Design Guide states that DisplayPort supports multi-head display through MST. Can Jetson Orin NX use a single DisplayPort MST connection to drive two independent displays as separate desktop outputs, or are the displays limited to mirroring the same image?
If independent MST outputs are not supported, what alternatives are available for driving two independent 4K displays from Jetson Orin NX?
Thank you for the detailed question about Jetson Orin NX DisplayPort MST capabilities. To provide you with accurate guidance on independent 4K display support and alternatives, we’ll need a few more details:
  1. JetPack/L4T version: Which JetPack version and L4T release are you planning to use?
  2. Expected behavior: Are you looking to extend the desktop across two displays (separate workspaces) or mirror content?
  3. Observed behavior (if testing): What happens when you connect an MST hub or second display?
  4. Reproduction steps: Have you tested this configuration yet, or is this pre-evaluation?
  5. Logs/screenshots: If you’ve attempted this, please share any relevant dmesg output or display configuration logs.
Once we have this context, we can provide specific guidance on MST support and alternative multi-display solutions for your use case.
Thank you for the response.
We are planning to use JetPack 6.2.2 with L4T 36.5.0.
The expected behavior is to extend the desktop across two displays so that each display can show independent content, rather than mirrored output.
We have not tested the configuration yet, this is currently part of a pre-evaluation stage. We are trying to confirm the supported display options before selecting the carrier board.
Ideally it is supported but MST seems to be case by case when different MST chip in use.
Also notice some MST chip won’t work on Orin NX.
As a follow-up, Seeed Studio helped RidgeRun test this configuration on the reComputer Robotics J4012, based on the Jetson Orin NX 16GB.
The test used a Saikang USB Type-C DisplayPort MST hub with dual HDMI outputs. With the hub operating in Join Mode, the Jetson drove two HDMI displays simultaneously with different content on each display, rather than mirroring the same output.
This test confirms that the Jetson Orin NX is capable of providing two independent display outputs through a single DisplayPort MST connection when used with a compatible MST hub.
