- Does Jetson TX2 support Wifi6 router connectivity?
It depends on the wifi card attached on Jetson TX2. If the wifi card support Wifi6, of course it should be able to connect to Wifi6 router.
But the wifi embedded in TX2 now as default only support 2.4G/5G. So TX2 don’t support Wifi6 router as default.
You can tried to find a Wif6 card which can also work on Jetson TX2.
Thank you for your patient answer. Are Jetson Xavier NX and TX2 the same?Does Xavier NX have interface for Wifi6 network card?
2021-02-26 15:20:04"alanz via NVIDIA Developer Forums" nvidia@discoursemail.com写道:
No, jetson xavier NX uses different wifi card from TX2.
