Does Jetson Xavier support RGB encoder?
From the “tegra_multimedia_api/samples/01_video_encode”, it seems that only YUV input is supported.
No, RGB format is not supported. You would need to convert the frames to YUV420 or NV12. If you use h265 encoder, you can convert to 10-bit NV12.
Yes, as @DaneLLL mentioned, you can’t encode it directly.
But you can check tegra_multimedia_api/samples/07_video_convert , it will tell you how to convert the format.
