I am using L4T R32.1 “Sample Root Filesystem” to flash the xavier. Are there JetPack 4.2 components like TensorRT 5.0.6 and VisionWorks 1.6 in it?
If not, how can I add these components into the “Sample Root Filesystem”?
The component like TensorRT is a standalone package.
You will need to download and install it with SDKmanager.
So after reflashing, just uncheck the ‘Jetson OS’ option to install the following packages with sdkmanager:
[ ] Jetson OS
> Jetson OS image
[V] Jetson SDK components
> CUDA
If I am using the sdcard as root file system, is it possible to install standalone package into sdcard through SDKmanager?
Thank.
I got the answer by my software. It is possible to install standalone package into the system on sdcard.
