Hello Gentleman,
We are following the use case on TX1 platform (L4T:24.2.1, Jetpack:2.3.1),
and we could capture the sensor data by the gstreamer command:
gst-launch-1.0 nvcamerasrc sensor-id=0 fpsRange="30 30" ! 'video/x-raw(memory:NVMM), width=1280, height=720, format=(string)I420, framerate=30/1' ! nvvidconv ! 'video/x-raw(memory:NVMM), width=640, height=480, format=(string)I420, framerate=30/1' ! nvegltransform ! nveglglessink -e
but when we execute the tegra_multimedia_api/samples/9_camera_jpeg_capture, we will get the error:
NvPclHwGetModuleList: No module data found
Sensor_LoadModeModeType: mode 0: Failed to load pixeltype
Sensor_LoadModePixelPhase: mode 0: Failed to load pixeltype
Sensor_LoadModeModeType: mode 1: Failed to load pixeltype
Sensor_LoadModePixelPhase: mode 1: Failed to load pixeltype
Sensor_LoadModeModeType: mode 2: Failed to load pixeltype
Sensor_LoadModePixelPhase: mode 2: Failed to load pixeltype
Sensor_LoadModeModeType: mode 3: Failed to load pixeltype
Sensor_LoadModePixelPhase: mode 3: Failed to load pixeltype
Sensor_LoadModeModeType: mode 4: Failed to load pixeltype
Sensor_LoadModePixelPhase: mode 4: Failed to load pixeltype
Sensor_LoadModeModeType: mode 5: Failed to load pixeltype
Sensor_LoadModePixelPhase: mode 5: Failed to load pixeltype
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
CONSUMER: Waiting until producer is connected...
PRODUCER: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
LSC:patch height less than 10LSC:patch height less than 10(NvOdmDevice) Error IoctlFailed: (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function setControlValMultiple(), line 620)
(NvOdmDevice) Error IoctlFailed: Coarse Time set failed (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function setControlVal(), line 411)
NvPclDriver_UpdateOutputSettings: Set Control failed. Use cached values
(NvOdmDevice) Error IoctlFailed: (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function streamControl(), line 1136)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
launchCC abort cc 104
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 731)
(Argus) Error Timeout: Failed to submit first capture request (propagating from src/api/CaptureSessionImpl.cpp, function submitCaptureRequests(), line 301)
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function threadFunction(), line 741)
Error: waitCsiFrameStart timeout guid 0
Error: waitCsiFrameStart Something went wrong with waiting on frame start
(NvOdmDevice) Error IoctlFailed: Gain set failed (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function setControlVal(), line 411)
Does anyone have an idea for this problem?
Thank you very much, if you have any question please feel free to ask.
Walker
