nvds_obj_enc_process crop() operates on NvDsFrameMeta which stores 2 types of dimension: source_frame_width & source_frame_height (camera dimension) vs. pipeline_width & pipeline_height (detector dimension). If camera dimension and detector dimension are different, at which dimension were the cropped images cropped?
Please provide more context for the use case. If we use the example in deepstream-image-meta-test, the crop will apply to the detector dimension. The original camera dimension may be scaled by nvstreammux before the detector, and the position information in metadata is in the same frame as detector , so detector dimension will be used.
Thank you for your reply. Yes, I have a nvstreammux that scaled the camera dims to the detector dims and I attached the probe after the detector element so does that mean pipeline_width & pipeline_height (detector dimension) will be used for cropping?
If camera dimension and detector dimension are different, in what situations would the camera dimension be used for cropping and in what situations would the detector dimension be used for cropping? In other words, what are rules that nvds_obj_enc_process crop() follows on picking which dimension to do the cropping?
Generally speaking, the rules only ralate to the paras in the api. You can refer the link below:
