• Hardware Platform (Jetson / GPU) GPU • DeepStream Version DS 6.2 • JetPack Version (valid for Jetson only) • TensorRT Version 8.5.3 • NVIDIA GPU Driver Version (valid for GPU only) 525.85.12 • Issue Type( questions, new requirements, bugs) question • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Is there any way to use nvdspreprocess element in case addition/deletion of camera source is dynamically done when pipeline is running.
Currently ROI information is being passed to nvdspreprocess element through config file. is there a way to reload config file while pipeline is running.
is there other way we can pass ROI information & network-input-shape?
can we set network-input-shape to <max_supported_camera>;3;16;224;224? e.g. 32;3;16;224;224
in my case, user can add/remove camera dynamically same as nvidia sample for add/remove runtime pipeline.
let’s say I start my pipeline with one camera with specific ROI information and then user wants to add more cameras to same pipeline with different ROI configuration.
I can manage by
Stopping pipeline
updated nvdspreprocess config file with new settings
Run pipeline
I am wondering if we have any other option to update nvdspreprocess configuration runtime without restarting pipeline.
We currently do not have support for this scenario. Could you try to set the config-file para again after you run the pipeline?
