Does NVIDIA ConnectX-7 (MCX755106AC-HEAT) Support Optical Linkup?
I am using ConnectX-7 (MCX755106AC-HEAT) dual-port QSFP NIC.
I have connected third party 400G QSFP112 LD SR4 optical module to the NIC QSFP port using MPO12 active optical cable.
Using ethtool utility, I can see various speed modes with LR, SR, DR and other ability are listed as supported.
Could you please help clarify the queries listed below:
  1. Does NIC card supports optical linkup ?
  2. How to tune NIC card for optical linkup without ANLT ? Are there mlx commands available to adjust tx-rx parameters manually.
  3. Does this NIC card supports linkup with optical transceivers and cables with ANLT ?
  4. Does the ConnectX-7 NIC support third-party QSFP112 optical modules, and are there any known limitations or issues when using non-NVIDIA optics ?
I can help answer a few of your questions.
Yes, ConnectX-7 does support optical link-up on QSFP112 ports.
ConnectX-7 supports optical modules and cables with IEEE auto-negotiation and link training. Most link issues with optics are caused by incorrect or incomplete EEPROM compliance advertisement.
Third-party QSFP112 optics can work, but they are not officially validated. If the module does not strictly follow IEEE specs (speed/FEC/AN), the NIC may detect it but keep RX disabled, resulting in no link.
