Does nVidia have verify any PCIe to USB 3.0 bridge IC on TX1/TX2 ?
Does nVidia have verify any PCIe to USB 3.0 bridge IC on TX1/TX2 ? Can you give the verify list ?
Hi Raylay,
We have checked variants uPD720200, uPD720201, uPD720202 and TUSB7340 are worked fine with/without AUX power.
Thanks for your quick reply !
In the datasheet the PCIe from the M.2 expansion slot are for Wi-Fi/ Bt option.
Is it still possible to use these chips with the M.2 slot?
Yes, the PCIe port on M.2 slot is standard port too.
Hi
Did you check those ICs with drivers for Linux(AARCH64) or windows?
