Does nvsipl_camera support on jetson agx orin?
Hi Nvidia:
I’m working on my serdes camera with max96717, max96712 customized board connected to jetson AGX Orin platform, and the camera works fine on argus_camera application.
Now I want to try nvsipl_camera on the same hardware setup.
My question is;
Does jetpack7.2 sipl camera support on AGX orin platform with customized serdes camera?
If not support, can I use the SIPL nito file on ARGUS camera? Is the file compatible with these two frameworks?
Thank you.
JetPack 7.2 / L4T r39.2 does support SIPL on Jetson AGX Orin. nvsipl_camera is the unified sample (/usr/sbin/nvsipl_camera). Please see the Camera Support Matrix: Camera Support Matrix — NVIDIA Jetson Linux Developer Guide
SIPL on Orin is a separate stack from Argus. Your MAX96717 + MAX96712 camera working in argus_camera uses the kernel V4L2 driver and device tree. That driver cannot be reused by nvsipl_camera. For SIPL you need:
  1. UDDF drivers for the deserializer, serializer, and module (rebuild against JP 7.2 headers; install under /usr/lib/nvsipl_drv/)
  2. A SensorSystemConfig JSON (nvsipl_camera -c <name> -H)
  3. A SIPL NITO under /var/nvidia/nvcam/settings/sipl/
Reference GMSL modules on JP 7.2 are AR0234 HAWK, SmartLead IMX728, and IMX623. A custom MAX96712/MAX96717 board is possible if the JSON and UDDF names match the hardware (link speed, FSYNC, RAW bit depth, embedded data).
Start with RAW capture (-r) to confirm the GMSL/CSI path, then enable ISP.
NITO is not compatible between SIPL and Argus.
  • Argus: /var/nvidia/nvcam/settings/, matched by camera badge
  • SIPL: /var/nvidia/nvcam/settings/sipl/, matched by module name
Do not use a SIPL NITO with Argus, or an Argus NITO with nvsipl_camera. If argus_camera already works, keep using that NITO on Argus. For SIPL ISP you need a NITO generated for the SIPL/CamPG tuning path.
Migration notes:
Hi ShaneCCC:
Thanks for your help.
I still confuse about the step 1. Is it not necessary to load kernel modules(e.g. max96717.ko, max96712.ko, imx728.ko) and only use UDDF to control my sensor, serializer and deserializer?
Also, what about the device tree? Do I have to remove the i2c client information(e.g. max96717, max96712, imx728) to prevent the device confliction while UDDF is running?
Thank you.
Suppose you can keep but need to take care of device resource using manually.
