Hi, I want to ask whether Omniverse USD composer actually supports custom GLSLFX shaders besides built-in USD shaders and MDL materials?
Looking at OpenUSD docs, it does say that it supports them. If you look at OpenUSD source code, there are also a bunch of GLSLFX shaders that they use for testing. It also seems that built-in USD shaders (e.g. UsdPreviewSurface) source code are actually written in GLSLFX. So I naturally assumed Omniverse USD composer supports custom GLSLFX shaders.
However, when I tried to open one of the sample USD scenes (which has GLSLFX shaders in it) in Omniverse, it just renders everything in red color. I even tried to open the same scene in UsdView and it actually renders normally! Below are the render results of Omniverse (left) and UsdView (right):
After further testing with several different GLSLFX shaders, none of them worked in Omniverse, while some are normal and others broken in UsdView.
Is this because USD framework used in Omniverse somehow differs from that of OpenUSD? Ultimately, what I want to ask is whether Omniverse USD composer supports custom GLSLFX shaders or not.
Thanks for your time reading!
