there are some flick issue caused by the 50Hz electric supply. seems did not enable the antibanding. does px2 support it and how to enable?
Dear xingxing,
Could you please upload the issued image or clip?
Please help to check DPX2 PDK, Aurix FW version and camera info.
DPX2 PDK version : 5.0.10.3?
Aurix FW : SW Version: DRIVE-V5.0.10-P2379-EB-Aurix-With3LSS-4.02.04?
Camera : AR0231?
hello xingxing,
could you please also share the status of 50hz flick issue, it would be great if having a video to identify the flicker.
thanks
链接: 百度网盘 请输入提取码 提取码: ayut
can you access the baidu server?
DPX2 PDK version :5.0.5.0bL
camera is ar0231-gmsl.
any other info do you need?
hi xingxing,
sorry, we cannot access baidu server.
could you please attach files to another cloud server.
thanks
upload to the google drive
hi
can you access the google drive link?
thanks
xingxing
hello xingxing,
yes, we saw the issue and we’re tracking this internally.
will update to you after we have some conclusions,
thanks
hello xingxing,
may I also have your confirmation that which driveworks release you’re installed?
you may need to check
$ ls /usr/local/driveworks*
thanks
Dear xingxing,
Could you please let us know how to capture the file you uploaded?
Did you use DriveWorks? or Nvmedia? Thanks.
we use the drive works to record the video. we just used the drive works in the pdk version 5.0.5.0bL
Dear xingxing,
Could you share or upload your using json file? Thanks.
json file
Dear xingxing,
Thank you for your update.
One thing, did you check this topic on new PDK(5.0.10.3) & DriveWorks(1.2.00)?
If you are able to update the PDK, could you please check whether the latest version also has this problem?
