Does saving the model with 'tf.saved_model.save' match this?
Version
tensorflow==2.0.0
Keras==2.2.4
tensorrt==7.0.0
ubuntu18.04
cuda10.2
Python 3.6.9
SavedModel
I don’t know which one to use for the SavedModel format, because the saved model formats are different.
In Case 1, since the layer information is not complete, it is unclear whether the model conversion is done properly with ‘trt.TrtGraphConverterV2’.
In Case 2, the layer information is completely written out, but it cannot be converted with ‘trt.TrtGraphConverterV2’.
It is a numerical image of the data MNIST used.
Please help someone.
[Case1]
tf.saved_model.save(model,saved_model_path)
$ saved_model_cli show --dir ./saved_models --all
MetaGraphDef with tag-set: 'serve' contains the following SignatureDefs:
signature_def['serving_default']:
  The given SavedModel SignatureDef contains the following input(s):
    inputs['input'] tensor_info:
        dtype: DT_FLOAT
        shape: (-1, 28, 28, 1)
  The given SavedModel SignatureDef contains the following output(s):
    outputs['dense_1/Identity:0'] tensor_info:
        dtype: DT_FLOAT
        shape: (-1, 10)
  Method name is: tensorflow/serving/predict
[Case2]
tf.keras.experimental.export_saved_model(model, saved_model_path)
MetaGraphDef with tag-set: 'eval' contains the following SignatureDefs:
signature_def['__saved_model_init_op']:
    outputs['__saved_model_init_op'] tensor_info:
        dtype: DT_INVALID
        shape: unknown_rank
  Method name is:
signature_def['eval']:
    inputs['conv2d_input'] tensor_info:
        dtype: DT_FLOAT
    inputs['dense_1_target'] tensor_info:
        dtype: DT_FLOAT
        shape: (-1, -1)
    outputs['loss'] tensor_info:
        dtype: DT_FLOAT
        shape: ()
    outputs['metrics/accuracy/update_op'] tensor_info:
        dtype: DT_FLOAT
        shape: (0)
    outputs['metrics/accuracy/value'] tensor_info:
        dtype: DT_FLOAT
        shape: ()
    outputs['predictions/dense_1'] tensor_info:
        dtype: DT_FLOAT
        shape: (-1, 10)
  Method name is: tensorflow/supervised/eval
        dtype: DT_INVALID
        shape: unknown_rank
  Method name is:
        dtype: DT_FLOAT
    outputs['dense_1'] tensor_info:
        dtype: DT_FLOAT
        shape: (-1, 10)
MetaGraphDef with tag-set: 'train' contains the following SignatureDefs:
        dtype: DT_INVALID
        shape: unknown_rank
  Method name is:
signature_def['__saved_model_train_op']:
    outputs['__saved_model_train_op'] tensor_info:
        dtype: DT_INVALID
        shape: unknown_rank
  Method name is:
signature_def['train']:
        dtype: DT_FLOAT
        dtype: DT_FLOAT
        shape: (-1, -1)
        dtype: DT_FLOAT
        shape: ()
        dtype: DT_FLOAT
        shape: (0)
        dtype: DT_FLOAT
        shape: ()
        dtype: DT_FLOAT
        shape: (-1, 10)
  Method name is: tensorflow/supervised/training
