Does Script Editor not support Environment Wrapper?
I am using Isaac Sim via AWS.
I have no idea how to use python evironment in Isaac sim with AWS so i try to do tutorial in Script Editor.
In Isaac Gym Tutorials, when i use try to run below code
from omni.isaac.gym.vec_env import VecEnvBase
I got the error
ModuleNotFoundError : No module named 'omni.isaac.gym"
also when I try to run below code
from stable_baseline3 import PPO
I got the error
ModuleNotFoundError No module named “stable_baseline3”
Is this problem from aws? or my installation?
I fixed first problem. By making omni.isaac.gym extension enable.
And the second is also solved.
In python environment, I tried
/isaac-sim/kit/python/bin/python3 -m pip install stable_baselines3 -i https://pypi.org/simple
