Does tensorrt allow variable input dimensions?
I’m working with a fully convolutional network with variable dimensions.
However when I try to declare dimensions as -1 in tensorrt it gives me an error.
Does tensorrt currently have support for variable sized inputs such as images? Thanks!
Michael
As far as I know, and in my experience, TRT is designed to work only for a fixed input size. It uses that static information (along with the network params, and GPU type, and who knows what else) to build its best execution engine it can for that particular setup. If you need a different setup, including different input dimensions, you need to build a new engine, but you can stash them for future use later using serialize and deserializeCudaEngine.
Good luck,
Tom
edit: corrected serializeCudaEngine -> serialize
Right, Trt does not support dynamic input size.
Thank you.
NVIDIA ENTERPRISE SUPPORT
