Does tensorRT3.0.2 support kernel size as 1*3 ? PX2 platform
i would like to known tensorRT3.0.2 is support convolution kernel size as 1*3.
and deconvolution as follow.thanks
layer {
type: “Convolution”
bottom: “concat”
top: “conv3x1_1”
param {
lr_mult: 0
decay_mult: 0
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
weight_filler {
type: “msra”
std: 0.01
bias_filler {
type: “constant”
value: 0.0
pad_h: 1
pad_w: 0
kernel_h: 3
kernel_w: 1
stride_h: 1
stride_w: 1
layer {
type: “Deconvolution”
bottom: “concat”
top: “deconv”
param {
lr_mult: 0
decay_mult: 0
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 0
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
Dear zhou-lw,
Do you notice any issue with this? If so, can you share prototxt and model file to reproduce it on our side.
