Does the function in classifier_parser work for each individual object when batch_size > 1?
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version
hello
I set batch_size = 8 of SGIE and made the parser function below work after classification in SGIE, but only one obj (individual) comes in, can you tell me why?
extern "C" bool NvDsInferClassiferParseCustomFaceRecognition(
    std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
    NvDsInferNetworkInfo const &networkInfo,
    float classifierThreshold,
    std::vector<NvDsInferAttribute> &attrList,
    std::string &descString)
What is your SGIE?
It is a FaceRecognize model, and TRT was created based on Onnx (Third-party REPO)
I didn’t use Nvidia-Tao separately
But I’m curious, is it possible to enter the custom_parser function in batch units?
This custom parse function is just a callback which parse one frame output of the batch.
Please refer to the function InferPostprocessor::postProcessHost() in /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer/nvdsinfer_context_impl.cpp
I looked at the line of code you mentioned, and it appears to me that the NvDsInferClassiferParseCustomSoftmax function handles objects one by one.
Am I right??
extern "C"
bool NvDsInferClassiferParseCustomSoftmax (std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
    /* Get the number of attributes supported by the classifier. */
    unsigned int numAttributes = outputLayersInfo.size();
    /* Iterate through all the output coverage layers of the classifier.
    for (unsigned int l = 0; l < numAttributes; l++)
        /* outputCoverageBuffer for classifiers is usually a softmax layer.
         * The layer is an array of probabilities of the object belonging
         * to each class with each probability being in the range [0,1] and
         * sum all probabilities will be 1.
        NvDsInferDimsCHW dims;
        getDimsCHWFromDims(dims, outputLayersInfo[l].inferDims);
        unsigned int numClasses = dims.c;
        float *outputCoverageBuffer = (float *)outputLayersInfo[l].buffer;
        float maxProbability = 0;
        bool attrFound = false;
        NvDsInferAttribute attr;
You can think so.
