does the intensive use of "if" statements increase the registry number
I have wrotten this kind of code to update seismic sources in a FD seismic propagation code. This code is mostly generated by script an use a lot of ‘if’ statements.
I don’t ask here if this kind of code is smart, that’s not my problem for the moment. My problem is that I don’t have enought ressources to run the code on my 8800GTX.
What surprises me is the number of registers used by the compiler:
ptxas info : Used 52 registers, 308+280 bytes lmem, 100+96 bytes smem, 2064 bytes cmem[0], 80 bytes cmem[1]
and here is the code : (c_* arrays are in constant memory)
[codebox]global void updateSources( int nbsources, int it, float dt, float* d_fx, float* d_fy, float* d_fz,
						int sizex, int sizey, int sizez, int pitchx, int sizex_tab, int sizey_tab, int sizez_tab, int pitchx_tab,
						int xshift, int yshift, int zshift)
int i = blockIdx.x*blockDim.x + threadIdx.x;
int j = blockIdx.y*blockDim.y + threadIdx.y;
for (int is = 0; is<nbsources; is++) {
	for (int k = 0; k < sizez; k++) {
		if ( c_insrc[is] == 1 ){
			int isource = c_ixhypo[is] - xshift;
			int jsource = c_iyhypo[is] - yshift;
			int ksource = c_izhypo[is] - zshift;
			float x_weight = c_xweight[is];
			float y_weight = c_yweight[is];
			float z_weight = c_zweight[is];
			float mo = c_vel[is][it] * dt;
			float pxx = radxx(c_strike[is], c_dip[is], c_rake[is]);
			float pyy = radyy(c_strike[is], c_dip[is], c_rake[is]);
			float pzz = radzz(c_strike[is], c_dip[is], c_rake[is]);
			float pxy = radxy(c_strike[is], c_dip[is], c_rake[is]);
			float pyz = radyz(c_strike[is], c_dip[is], c_rake[is]);
			float pxz = radxz(c_strike[is], c_dip[is], c_rake[is]);
			int offset = k*(pitchx_tab)*(sizey_tab) + j*(pitchx_tab) + i;
			if (i == isource-1) {
				if (j == jsource-1) {
					if (k == ksource-1) {
						d_fy[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fz[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)));
					else if (k == ksource) {
						d_fy[offset] -= (0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pyy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
						d_fz[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
					else if (k == ksource+1) {
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pyy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
						d_fz[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
					else if (k == ksource+2) {
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
				else if (j == jsource) {
						d_fy[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)));
						d_fz[offset] -= (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pzz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)));
						d_fx[offset] -= (0.5 * mo * pxx * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fy[offset] -= (0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pyy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pyy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fz[offset] -= (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pzz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pzz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fx[offset] -= (0.5 * mo * pxx * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.5 * mo * pyy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*z_weight))-(0.5 * mo * pyy * ((1.0 - x_weight)*y_weight*z_weight));
						d_fz[offset] -= (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.5 * mo * pzz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight));
				else if (j == jsource+1) {
						d_fy[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pzz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)));
						d_fx[offset] -= (0.5 * mo * pxx * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)));
						d_fy[offset] -= (0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.5 * mo * pyy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.5 * mo * pzz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*z_weight))-(0.5 * mo * pzz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fx[offset] -= (0.5 * mo * pxx * ((1.0 - x_weight)*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*z_weight))+(0.5 * mo * pyy * ((1.0 - x_weight)*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*z_weight))+(0.5 * mo * pzz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight));
				else if (j == jsource+2) {
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight));
			else if (i == isource) {
						d_fy[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fz[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fx[offset] -= (0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fy[offset] += (0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pyy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pyy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fz[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fx[offset] -= (0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pyy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*z_weight))-(0.5 * mo * pyy * (x_weight*(1.0 - y_weight)*z_weight));
						d_fz[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fx[offset] -= (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fy[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fz[offset] += (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pzz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pzz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fx[offset] -= (0.5 * mo * pxx * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pyy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pyy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pyy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxy * (x_weight*y_weight*(1.0 - z_weight)))-(0.5 * mo * pyy * (x_weight*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight))-(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pzz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pzz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pzz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*z_weight))-(0.5 * mo * pzz * (x_weight*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight))-(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxx * (x_weight*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.5 * mo * pyy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pyy * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*z_weight))-(0.5 * mo * pyy * ((1.0 - x_weight)*y_weight*z_weight))-(0.5 * mo * pxy * (x_weight*y_weight*z_weight))-(0.5 * mo * pyy * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.5 * mo * pzz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pzz * (x_weight*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight))-(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight))+(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight))+(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fx[offset] -= (0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)));
						d_fy[offset] -= (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pzz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxz * (x_weight*y_weight*(1.0 - z_weight)))-(0.5 * mo * pzz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fx[offset] += (0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxx * (x_weight*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fy[offset] += (0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.5 * mo * pyy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxy * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pyy * (x_weight*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight))-(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.5 * mo * pzz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pzz * (x_weight*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*z_weight))-(0.5 * mo * pzz * ((1.0 - x_weight)*y_weight*z_weight))-(0.5 * mo * pxz * (x_weight*y_weight*z_weight))-(0.5 * mo * pzz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.5 * mo * pxy * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxx * (x_weight*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*z_weight))+(0.5 * mo * pyy * ((1.0 - x_weight)*y_weight*z_weight))-(0.5 * mo * pxy * (x_weight*y_weight*z_weight))+(0.5 * mo * pyy * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*z_weight))+(0.5 * mo * pzz * ((1.0 - x_weight)*y_weight*z_weight))-(0.5 * mo * pxz * (x_weight*y_weight*z_weight))+(0.5 * mo * pzz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxz * ((1.0 - x_weight)*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight))+(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fx[offset] += (0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight))+(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxy * ((1.0 - x_weight)*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * ((1.0 - x_weight)*y_weight*z_weight))+(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
			else if (i == isource+1) {
						d_fy[offset] -= (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fz[offset] -= (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fx[offset] -= (0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fy[offset] += (0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pyy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fz[offset] -= (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fx[offset] -= (0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*z_weight))-(0.5 * mo * pyy * (x_weight*(1.0 - y_weight)*z_weight));
						d_fz[offset] -= (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fx[offset] -= (0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fy[offset] -= (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fz[offset] += (0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pzz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fx[offset] += (0.5 * mo * pxx * ((1.0 - x_weight)*(1.0 - y_weight)*(1.0 - z_weight)))-(0.5 * mo * pxy * (x_weight*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pyy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxy * (x_weight*y_weight*(1.0 - z_weight)))-(0.5 * mo * pyy * (x_weight*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pzz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*z_weight))-(0.5 * mo * pzz * (x_weight*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxx * ((1.0 - x_weight)*(1.0 - y_weight)*z_weight))-(0.5 * mo * pxy * (x_weight*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pyy * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pxy * (x_weight*y_weight*z_weight))-(0.5 * mo * pyy * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pzz * (x_weight*(1.0 - y_weight)*z_weight))-(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxz * (x_weight*(1.0 - y_weight)*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight))+(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fx[offset] -= (0.5 * mo * pxz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fy[offset] -= (0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fz[offset] += (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxz * (x_weight*y_weight*(1.0 - z_weight)))-(0.5 * mo * pzz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fx[offset] += (0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxx * ((1.0 - x_weight)*y_weight*(1.0 - z_weight)))-(0.5 * mo * pxz * (x_weight*y_weight*z_weight));
						d_fy[offset] += (0.5 * mo * pxy * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pyy * (x_weight*y_weight*(1.0 - z_weight)))-(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)))+(0.5 * mo * pxz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pzz * (x_weight*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pxz * (x_weight*y_weight*z_weight))-(0.5 * mo * pzz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pxy * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pxx * ((1.0 - x_weight)*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)))+(0.5 * mo * pxy * (x_weight*y_weight*z_weight))+(0.5 * mo * pyy * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * (x_weight*(1.0 - y_weight)*z_weight))+(0.5 * mo * pxz * (x_weight*y_weight*z_weight))+(0.5 * mo * pzz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxz * (x_weight*y_weight*z_weight));
						d_fy[offset] += (0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)));
						d_fx[offset] += (0.5 * mo * pxy * (x_weight*y_weight*(1.0 - z_weight)));
						d_fz[offset] += (0.125 * mo * pyz * (x_weight*y_weight*(1.0 - z_weight)))+(0.125 * mo * pyz * (x_weight*y_weight*z_weight));
						d_fx[offset] += (0.5 * mo * pxy * (x_weight*y_weight*z_weight));
						d_fz[offset] += (0.125 * mo * pyz * (x_weight*y_weight*z_weight));
			else if (i == isource+2) {
				if (j == jsource) {
					if (k == ksource) {
						d_fx[offset] += (0.5 * mo * pxx * (x_weight*(1.0 - y_weight)*(1.0 - z_weight)));
						d_fx[offset] += (0.5 * mo * pxx * (x_weight*(1.0 - y_weight)*z_weight));
					if (k == ksource) {
						d_fx[offset] += (0.5 * mo * pxx * (x_weight*y_weight*(1.0 - z_weight)));
						d_fx[offset] += (0.5 * mo * pxx * (x_weight*y_weight*z_weight));
	__syncthreads();
}[/codebox]
As you can see, i use few variables, just constant memory arrays for reading et 3 global memory arrays for read + write
It’s the first time i use so many if statements in a CUDA code, and the first time i need so many registers and local memory …
Is this a consequence of the massive use of if statements ? how can i reduce the amount of registry/localmem used ?
thanks.
I think a co-worker of me noted something like this a while ago. However I think his problem was that using nested for loops would make the register count explode. I did not have time to look into the problem back then, therefore I don’t know whether that was actually the cause or something else was causing the compiler to hog registers.
with the use of the noinline function qualifier for the device functions used in this kernel, there is a small improvement :
ptxas info : Used 28 registers, 308+280 bytes lmem, 100+96 bytes smem, 2064 bytes cmem[0], 104 bytes cmem[1]
But this not satisyng since the compiler still use a lot of local memory (i guess lmem is local memory), which has very low access …
Further more, I foud that in the .ptx file :
.entry __globfunc__Z13updateSourcesiifPfS_S_iiiiiiiiiii
    .reg .u16 %rh<12>;
    .reg .u32 %r<245>;
    .reg .u64 %rd<213>;
    .reg .f32 %f<411>;
    .reg .f64 %fd<1122>;
    .reg .pred %p<70>;
I don’t use any double in my code (and the card i use has a compute capability of 1.0), so why does it use 64bits floating point registers ???
Where could i found a list of all compiler options for nvcc ? I think the problem is that the compiler seems to ‘think’ there are some dependances between the if statements where there is none. So it uses a lot of different registers to store the intermediate results when it is not necessary …
but the compiler do not care of what I say …
First off, make sure you write immediate floating point numbers in your code like so: 132.85f If you miss the little f at the end, the compiler will interpret those as double precision. Very annoying.
As for the rest of the question, I find that a good way to reduce register usage is to put a syncthreads() after each divergent section, like so:
if (divergentCondition)
syncthreads();
The syncthreads() will let the compiler know that there are no more carried over dependencies, since they will all be resolved at the synchthreads(). In addition, you can use syncthreads() anywhere you know the branch will be uniform, i.e. not diverge.
Looking at your code, it looks like you need to factor the math. Compute as much as possible outside of the ifs, and then combine using predicates from inside the ifs.
i.e.
Replace:
if (j < 1)
z=xx+yy;
else
z= xx-yy;
with:
if ( j < 1)
pred = 1;
else
pred = -1;
z = xx+predy*y;
