We are currently testing a monitor. Does the AGX Orin HDMI support high refresh rates of 480Hz and above?
1920x1080 resolution
For Jetson AGX Orin HDMI, 1920x1080@480Hz or higher is not in the documented supported HDMI mode list.
HDMI support
The Jetson Orin HDMI support table documents HDMI 1.4 modes including1080p, and HDMI 2.0 modes up to4K@60. The same section notes that Jetson Orin HDMI passed HDMI 2.1 certification, but only the features listed in that table are supported:
Jetson Orin Series — NVIDIA Jetson Linux Developer Guide -
AGX Orin Developer Kit
If you are using the Jetson AGX Orin Developer Kit, please note that the dev kit has DisplayPort as its only display interface. HDMI monitors would require a DP-to-HDMI adapter:
Hardware Layout — NVIDIA Jetson AGX Orin Developer Kit - User Guide
Recommendation: Please use a display mode within the documented supported HDMI/DP matrix. We do not claim support for 1920x1080@480Hz or higher over AGX Orin HDMI.
Hope this helps!
