Does the jetson nano dev kit support a USB stick modem (3G/4G/5G)?
if so, is there any requirement for it?
It isn’t a case of the Jetson supporting this, it is a case of whether you have a driver installed. If the kernel source has the driver available, then you would build and install the driver. If the driver is not available in the source, but the manufacturer provides a binary-only driver, then they would need to provide an arm64/aarch64 binary (because that is the architecture of the CPU).
