Does the jetson TX1 ISP can support imx179 sensor chip?
hello sensor_test,
may I know what’s the functionality you need TX1’s ISP working with?
we must need your use-case and more details about this IMX179 sensor.
however, there are several NVIDIA Jetson preferred partners: [url]https://developer.nvidia.com/embedded/community/partners[/url]
please contact them to have further support,
thanks
I need use the imx179 mipi sensor as same as the imx274.
for exmaple,TX1 can support imx179 3A etc ISP processor?
hello sensor_test,
may I know what functionality you need TX1’s ISP working with?
ideally, ISP is able to process bayer sensor and handle most of use-case.
since there are Jetson camera partners who provides solutions,
please contact [url]https://developer.nvidia.com/embedded/community/partners[/url], share your use-case to them and get further support.
thanks
Hello JerryChang,
I will use own design the imx179 module.
then we need own design the dtsi file and device source code file.
Maybe you can offert some help for this?
hello sensor_test,
again,
