Does the M.2 Key E interface of Xavier NX support Wifi 6?
Is there an adapted WIFI 6 module? Judging from the interface of Xavier NX DK, it seems that it only supports WIFI 5? Thank you
What’s the data rate request of your device? It’s x1 PCIe GEN3 port on the M.2 Key E connector.
thank you for your reply. Our customers use Xavier NX for virtual reality modeling and multiplayer games, which require higher transmission rates, lower latency and multi-user use.
Wifi 6 is more suitable, so can the interface of M.2 Key E support wifi 6?
From the point of view of the carrier board specification, the interface of M.2 Key E only supports 802.11.ac, not 802.11.ax.
It depends on the data rate request of wifi 6 device. Which doc do you mean in which says only support 802.11ac for Key E?
