Both Jetson & dGPU
• DeepStream Version
6.2
5.1
• TensorRT Version
Questions based on observations…
We have a single RTSP Camera with the following settings
Fps = 25
Keyframe = 50
When setting the nvv4l2decoder’s skip-frame
property to 0
to decode every frame, the Pipeline runs well without any qos, warning, or error messages.
When we set skip_frames=2
to only decode the keyframes, we start to see a flood of qos messages from the decoder. What is interesting is that the qos messages show a single frame being decoded roughly at the same interval as the Keyframe.
Just filtering on the messages that show the change in the number of decoded frames
The first buffer to be processed happens after 60 buffers are dropped,
: Message type : qos
: source : source-701-42530-nvv4l2decoder
: format : buffers
: processed : 0
: dropped : 60
: format : buffers
: processed : 1
: dropped : 61
The next after the 85th buffer has been dropped
: format : buffers
: processed : 1
: dropped : 84
: format : buffers
: processed : 2
: dropped : 85
The next at 109
: format : buffers
: processed : 2
: dropped : 108
: format : buffers
: processed : 3
: dropped : 109
My questions are
- does the decoder use the qos message to report skipped frames?
- or is setting the
skip-frames
property somehow causing qos issues?
Thanks,
Robert.
