When a vertical thrust and a z-axis moment are applied to a quadrotor’s propeller (all propellers’ thrusts and moments are equivalent), the quadrotor is expected to move vertically up and down (following the z axis), but the simulation result is that the quadrotor shifts in the x-y plane except for the vertical up and down motion. I want to know is this caused by random noise from the physics simulation?
Related topics
Topic | Replies | Views | Activity | |
Robot oscilation in Isaac Sim | 8 | 751 | January 17, 2024 | |
Applying external forces to a robot body in IsaacLab | 2 | 107 | March 8, 2025 | |
Movement in joints | 2 | 1234 | August 16, 2022 | |
How to implement a vacuum force in Isaac Lab | 0 | 49 | August 22, 2024 | |
Omniverse Isaac sim Sensor data | 3 | 829 | January 16, 2024 | |
Noise and deviations in sensors(velocity) from wheel | 2 | 641 | April 5, 2024 | |
Robots in Isaac Sim Examples do not move in containers from today suddenly | 1 | 324 | April 5, 2024 | |
The forces read with the joint force sensor are unreasonably high | 11 | 723 | December 25, 2024 | |
[Bug Report] Articulations with cylinder-based collisions fall through default ground plane in Isaac Sim 2022.2.1 (GPU PhysX) | 1 | 669 | August 30, 2023 | |
Create articulations on robot | 3 | 566 | April 5, 2024 |
