Does this I2C bus require two external pull resistance for jetson tx1 use i2c 0?
may i know your use-case, thanks
1.I use the IMX219 sensor to the camera i2c,now I NEED two external pull resistance for imx219 i2c ,is OK or NO?
2.The camera i2c is " i2c6 = “/host1x/i2c@546c0000"”, is OK or NO?
3.How can I use command the test the amera i2c? is “sudo i2cdetect -r -y 6” OK or NO?
hi sensor_test,
it looks like the same topic issue 1031591 you filed.
let’s moving to there to keep the discussion in the same forum thread.
thanks
