• Hardware Platform (Jetson / GPU) GPU • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
hello
I’m testing with a single image stream (it causes tracker_confidence > 0.99), and when I add a tracker, it suddenly appears as if agnostic-nms is applied. Does that actually work in the internal implementation?
It is only for demo. Not include it in the DeepStream release.
