Does Workbench have a template/example starting point or guide?
Is there any documentation about how the AI Workbench project repository is structured?
I’m talking about things like code/data/models, along with .project/spec-yaml, pre/post build, etc.
I think we’re doing OK fumbling through various aspects, and borrowing from random repos or just setting up a new project, but my gut says there is probably something out there that already exists as a starting point? And/or, is there documentation that explains what all the things are and how they are used?
I know we can do it through AI Workbench, but there’s quite a bit I can do outside of NVWB and I’d rather work locally until I have a reason to clone.
Please describe your issue or request: (tick the boxes after creating this topic):
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
TLDR
Yes, there’s documentation. We want to improve it, so critical feedback is very valuable. See below for relevant docs.
Outside of the project specification and the required fields and locations for certain files (.project, requirements.txt, etc), the project structure is flexible and up to an end user.
For example, you aren’t tied to the code, data and models folder structure. You can change that as well as indicate the versioning backend as you wish.
However, you need to manually edit the spec.yaml file to account for these changes. We don’t yet have affordances in the UI or CLI for this aspect.
Specific References
Here’s the overview: AI Workbench Projects - NVIDIA Docs
Here is a fairly dry description of the “project specification”: AI Workbench Project Specification - NVIDIA Docs
The project specification is also related to an image label specification that’s used for the base containers. You can see more on that here: Use Your Own Container - NVIDIA Docs
There also a “quick start” on building your own base image for import into Workbench: Advanced Walkthrough: Use Your Own Container - NVIDIA Docs
These Specific References are awesome and exactly what i was looking for related to docs. Thank you!
Is there a link that describes configpacks? A quick search showed only the following from [AI Workbench Projects - NVIDIA Docs]
.project/configpacks
Used by AI Workbench to track when configpacks are run to prevent duplication
There isn’t but the feature isn’t fully ready for users to start adapting it. At the moment, it’s more or less an internal.
